Streetmilitia13
Looking on input for leveling my Ram Bighorn. I would like to level it, not sure if spacers are the way to go and if so, should I enlarge the tires?
I used 2.5" superlift spacers on mine. Easy install no change in ride at all. I was able to fit 35's but only after 1.5" spacers.Looking on input for leveling my Ram Bighorn. I would like to level it, not sure if spacers are the way to go and if so, should I enlarge the tires?
Why is putting bilsteins on "doing it right"? For a 2 inch level the added cost doesn't make sense. Spacers are proven easy technology that is much cheaper and if you buy quality and install right you will never have an issue. To each his own but don't say one is right and one is wrong. Also you will never have to replace a spacer, those holsteins will eventually need to be replaced.Do it right and put Bilstein's at no more than 2.1" setting on it, on the front and call it a day. do it right the first time and not worry about any potential other suspension issues. take that peace of mind money you'll save and put a little bigger tires on it, if you want. On the tires you'll have weigh looks, frankly against budget. in canada, the price difference is so huge changing from stock tire sizes it can be a case of 25 to 40% more for an inch of tire height difference. its just not worth it to me at that price.
It depends on how much lift you want and what kind of condition your current suspension is in. Since you said level, I assume you’re looking for the typical 2 inches or so up front and nothing in the rear? If it has a lot of miles on it and you think it could benefit from new struts anyway, then I’d kill two birds with one stone and put the Bils 5100 in the front and be done. But, if your struts are in good shape and your happy with everything other than wanting to level it out, there’s nothing at all wrong with spacers. Just don’t go with the cheapest spacers you can get. The generic open top spacers (the kind that is just a big aluminum circle with a large opening in the center) can cause your upper strut mount to prematurely fail. I’m not trying to promote any particular brand, but I used the Rough Country 2” leveling kit up front and am very happy with it.
Yup, what you said. No need to go expensive with struts on a 45k mile truck. He won't benefit in any way.It depends on how much lift you want and what kind of condition your current suspension is in. Since you said level, I assume you’re looking for the typical 2 inches or so up front and nothing in the rear? If it has a lot of miles on it and you think it could benefit from new struts anyway, then I’d kill two birds with one stone and put the Bils 5100 in the front and be done. But, if your struts are in good shape and your happy with everything other than wanting to level it out, there’s nothing at all wrong with spacers. Just don’t go with the cheapest spacers you can get. The generic open top spacers (the kind that is just a big aluminum circle with a large opening in the center) can cause your upper strut mount to prematurely fail. I’m not trying to promote any particular brand, but I used the Rough Country 2” leveling kit up front and am very happy with it.
They have always been fine. People cheap out and buy $20 pucks then come on here and ***** about them.Man since when spacers were this good all of a sudden?. I'm scared if i don't get a pair now they'll run out of stock hahahaha.
Ah ok so if i get the $50 ones you think i'll be ok?They have always been fine. People cheap out and buy $20 pucks then come on here and ***** about them.
Nope. Mine were 150. Had them on for years about 50k miles not a single issue. They only came off because I lifted the truck. They looked brand new when they came off. Ignorance is bliss though...Ah ok so if i get the $50 ones you think i'll be ok?
$150 for spacers ? damn.Nope. Mine were 150. Had them on for years about 50k miles not a single issue. They only came off because I lifted the truck. They looked brand new when they came off. Ignorance is bliss though...
