Part numbers
Timothy Bierley
Alabama
I have 2012 Ram 1500 with a 3.7 in it. The oil that came on the truck when I got is AC oil filter. What is part numbers for a Mopar and a Royal purple oil filter. I am going to run Royal purple oil.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Check 10-48 Royal Purple--At least that is the one for my 16. It might fit yours also
Jay
I just re-read your post and see you have a 3.7. I don't think the RP part numbers will work for your application--they are for a 5.7----sorry the confusion--I need to do a better job of reading I guess!!!!!
Jay
tantore
texas
you must have the 5.7 hemi the mopar filter is mo 899 royal purple is 20-820
Cableman
Longisland
Does anyone run the 20-820 on a 2016 or above?
The mounting flange looks so much smaller then this filter, not sure if earlier years are different. I read some have leaks using this bigger filter.
