Oil Filter Cap
VCorleone
Chester County, PA
3.7L V6
Hello all.
Did my first oil change on my new to me 2017 Ram 1500 Big Horn and would like to avoid using an adjustable wrench to remove the cap over the oil filter housing the next go around.
If a regular sprocket is good, what size? If not, what are you guys and gals using on your trucks?
chrisbh17
Cap over the oil filter? Are you referring to an oil filter wrench?
O had the dealer do my first oil change because FCA hired a gorilla to install the filters from the factory. Since then, I do my own oil changes and only put the filter on hand tight. Warm up the truck enough and with a good grip (gloves) and some elbow grease I can start to remove the oil filter by hand, no wrench required.
I had a pliers type filter wrench hanging around and it does work if necessary, you just need to finagle it into place.
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
Looks like the OP has a Pentastar V6 and I use a 15/16" 6 point socket on a flexhead ratchet, it works perfect and you don't have to remove the shroud to get at it.
VCorleone
VCorleone
Chester County, PA
3.7L V6
Yes to the Pentastar. I'll give the 15/16 a try. Thanks.
Oops....I guess giving the specific engine specs would have been a good thing. Sorry about that.
Administrator
You can also use a 24mm for the oil filter cap.
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
One or the other, just use a 6 point and be careful as some members have cracked theirs from over tightening.
Badger 13
North Idaho
2013 Dodge Ram 1500
I use a Lisle 24mm socket,
Lisle 13310 Low Profile Filter Socket, 24mm
on our Wrangler with the 3.6 engine that works well, inexpensive and available in many stores, including amazon. There is also another "wrench" available for this is well. Do a search for a Jeep Wrangler oil filter wrench and you will find it. I wish the HEMI oil filter was that easy to change...
46RamMan
U.S. Navy Veteran
Missouri
I have heard that a 15/16 socket will work also. Gonna try it this friday on our JKUR:):birgits_tiredcoffee
1Popeye
