Jackson Wright
Hey, new to the forum. I have a 96 5.9 1500 auto that's started making a metal rubbing noise after I did an oil change on it. The noise seems to get worse after coming to full stop or taking a corner in either direction. Oil pressure gauge has been acting normal. I'm having trouble hearing exactly where the noise is coming from so if anyone has any ideas based off the symptoms any advice is appreciated. The noise isn't a grinding noise but more as if a dust cover is dragging along a rotor but what throws me of is not being able to tell where exactly the noise is and it happening worse at complete stops. It does happen while the vehicle is moving too just not as bad and it doesn't happen every stop or corner.
