Nystagmus
- Joined
- Oct 25, 2017
- Posts
- 267
- Reaction score
- 161
- Location
- NE Arkansas
- Ram Year
- 2015 Longhorn CC
- Engine
- 5.7
So, I took my truck in over the weekend for an oil change and told them to check the alignment due to a slight pull to the right.
when I picked up my truck I immediately noticed that the pull had not been corrected at all and took it back. Supposedly the did some slight adjustments and said it was perfectly aligned, but still had a slight right pull.
See attached print out of the “after” settings. Is there any reason for the left front to not be in the green zone and could this cause the pull to the right ? I have no knowledge of the geometry under there things !!
