Keppie
- Joined
- Jan 25, 2019
- Posts
- 1
- Reaction score
- 0
- Location
- Placerville, California
- Ram Year
- 1999
- Engine
- 5.9L
Checked other threads on brake pedal probs that were kinda like mine....very discouraging.....
I've got a 1999 2500 with 90K miles. Runs great!! And the brakes work absolutely perfectly.
But...when the temp outside goes below 40 degrees or so, my brake pedal will not return fully. When the pedal is depressed for braking and released, it returns to this "sticky" position about 1/2 inch (or less) of travel from normal position. In this position, the brakes remain lightly applied and the brake lights stay lit. Quick toe lift of the pedal, and away we go.
Thankfully, this truck is not a daily driver and doesn't get used very often. When I do use it, I have gotten real good at left foot toe lifts under the pedal which gets the job done...but it is a nagging issue.
What say? Anyone experienced this temperature related brake problem?
Thanks, Keppie
Thanks, Keppie
