Yes sirYou gonna keep the Viper style wheels?
Thanks I have one just didn't take a picture of it. I hope it comes out right I pieced together a kit so it would sit just about what I imagineYou might want to find a polyurethane bushing or.. something.. that you can pack that spacer with. https://www.ramforum.com/threads/dont-use-open-top-level-spacers.134098/
I see what you're talking about now. Is there a different spacer I can use instead that doesn't have an open top?You might want to find a polyurethane bushing or.. something.. that you can pack that spacer with. https://www.ramforum.com/threads/dont-use-open-top-level-spacers.134098/
Are you 4wd? And how much lift is that spacer advertised as?I see what you're talking about now. Is there a different spacer I can use instead that doesn't have an open top?
Yes 4wd, the open spacers are 1.5"Are you 4wd? And how much lift is that spacer advertised as?
https://www.americantrucks.com/mamm...CixVFS8ZTi3-zyfj-IyOzWEFpHaue4txoC9okQAvD_BwEYes 4wd, the open spacers are 1.5"
https://www.americantrucks.com/mammoth-2-leveling-kit-0618-4wd-ram-1500.html?utm_content=AT Lift Kits - Leveling Kits and Body Lifts|Mammoth&T5_Var4=R107249&utm_campaign=AT+Brands+Medium+RLSA&dialogtech=ppc&utm_source=google-pla&utm_medium=shopping&T5_Var2=shopping&T5_Var3=red&gclsrc=aw.ds&&gclid=CjwKCAiAluLvBRASEiwAAbX3GZXDsUbXYmH49u-SEsrZ4oCixVFS8ZTi3-zyfj-IyOzWEFpHaue4txoC9okQAvD_BwE
So I am running a mammoth 1.5" lift spacer (1 1/16" thick) on my setup. The center supports the top of the coilover perfectly. And they are pretty cheap. Haven't had a single issue with mine compared to the one I pulled out in the thread I started about them.
The one I linked was just a quick Google search for the brand so I could show you.
Correct. You want a small enough hole that the busing can't push through the top, just the stud and nut for the shock shaft. Otherwise the top bushing isn't supported and free floats inside the spacer.So if I'm looking at this right, these have a smaller hole in the center so it can't push through? Right?
Most people just use Bilsteins (or other lift struts) to side step this problem entirely.
What you could do is find a donut shaped suspension bushing and cut it down to fit in there, just to serve as an isolator so the top of the upper strut mount can resolve its forces against that and never become a problem (and never make noise, either.. also a good thing) - for example these bushings from a Mitsubishi truck are a little bit too big to just push straight in, but that means if you cut them down (bandsaw, oscillating saw..) they would push right in and fill it.
Or you could find some washers the right size and fill 'em in there... or use Windo-Weld... or even build it out with Steel Stik epoxy. None of those are "show quality" fixes but the only thing they need to do is give the inner bushing on your struts a way to transmit their force up to the truck's frame. You could smash cheeseburgers in there and if they're tight enough it would work, you know?
You got the yellow Bilsteins right? The front ones have an optional 0.7" lift built into them.. if that's enough for what you're doing. It's the default ride height for the Outdoorsman trucks.. or I'd return those spacers you got and get the small hole spacers. Or return the front struts and the spacers and get 5100's.
