gablett
Not true:
https://www.blackstone-labs.com/wp-content/uploads/2018/09/Aug-17-ENG.pdf
Even Subaru oil has it.
Has it, yes. But not in high quantities.
Not true:
I also called a local auto supplier - Trackwerks - that has Redline, 5w-20 or 0w-40 at $20.99 a quart.Cheers!
The results are speaking for themselves... 24-1 now on improving or eliminating the tick vs not helping at all. I’m glad this thread started just in time for me to get my redline in today
What’s the math on the peopling that it hasn’t helped?WOW! that is .000284275 of all the members here. YES! it says RL doesn't do it for a lot of engines.
What the math on the peopling that it hasn’t helped?
Why must you **** all over this thread,
Previously answered when one of the other RL Posse asked.
Mr Dexter asked how much moly is in redline, its up in the triple digits 5-600? not double digits i believe.
Hay Undexterity, Go get a life on another forum your comments are not wanted here.
Watch the video I attached here about the lifter. It has nothing to do with the oil. In the video it says that the problem occurred in pre 2016 engines.
PUP has a high amount of Moly. see the link in my signature line.
Believe all you want. Some people still believe in the boogy man. I know it is less.
Not Redline high. Not even half of Redline.
Many blackstone reports on here with your "proof". I am also joining the ignore you crew, aka the RL posse. Good bye forever sir.
Post deleted. But it was good.How his is the sky?
How much Moly does an engine need anyway. Give us some numbers Shane.
What does it have and what to other oils have.
While you are at it provide how RL and other oils contain zinc and phosphorus (ZDDP). Those are wear protection additives as is moly.
