Adjusted my doors.
PaPitt
Stephenville TEXAS 76401
5.9L
SO i Have this ''old'' 1988 3/4ton flat bed that I use on my farm. It has a Western Hauler bed on it & The hyd wrecker hithch has been converted int a hay spear for the farm. & The truck onlyshows 44K on it . I expect it's 144K but it sure steers nice . But it was on a ranch for ever. SO it just might be 44K.
BUT ON RANCHES .. Cowboys have a tendency to not shut the doors ... Which let's them sag & Not shut correctly ..
... SO SINCE I WORKED IN TOWN & Owned a parts store that sold a lot of paint in central TEXAS .
.. I'VE DEALT witha lot of bodyshops.. & Back in those days. I was 1967 until 1995..
SO I watched them pull frames & adjust doors.
... SO My doors would just not adjust correctly ... I though I was slipping.
So I'd figured out how to shut my doors while driving in the pasture. But at times I had to shut them 7 times before i GOT THEM CLOSED .
.... bUT YESTERDAY . I walked through myshop & I saw a tool I'd bee looking for .. Big tire tool.
I've just sold my big tractor . A DUAL WHEEL 1586 IH .. 150HP TRACTOR . IT'S GONE .
bUT UNDER WHERE IT HAD SET. was mytire tool.
It was that slide hammer . for busting off the tires from the rear tractor tires .
... It's a slide hammer . The inside slide weights about 20lb. & The rest of the hammer might weigh 35lbs.
... But I'd thought if I could hit that top heinge with that tool . I might could move that hinge forward enough to make my door shut.
... So I took my tool , i'd found. & Placed the flat front edge against top hinge & Gave the 20lb bar a slap.
& Another & a total of maybe 4 or 5 . & Then I thought I've got in several good licks in . I might should try this.
.... Wow I gave the door a shove & it shut ... So I tried it several more times . I looked at the gap. & Yes the gap look great .
..... I hope you can understand what I did & I hope you can shut your old door.
