400 psi
I have done some searching on here in the past few weeks since becoming a new owner and just want to confirm my understanding of how best to use the truck. Thanks all for your insight and informative posts. it has helped me a lot so far
Three weeks ago I purchased a 2018 CC bighorn 12k miles on odo with 3.6 3.55. I purchased this to tow a 3900# GV 17bh camper, that I just bought, and a 12' V-nose to haul my dirt bike three times a year (any other times I have a utility trailer that I drag it around on). Other than that, gas mileage, comfort for traveling, and ease of a six year old getting into at car line were the other factors. I live in the mountains of Western NC and we typically will camp around the south east. The truck has a class IV receiver.
From my reading, I understand the 8speed transmission to have two overdrive gears, that with tow haul engaged , it still allows the use of the overdrive gears, it just changes the shift points and allows for more engine braking. Tow haul typically engages the transmission at max 5th gear?
If I want to control the gearing, based on the transmission searching or a steep climb etc , I can control the top gear by wheel controls accordingly.
I just want to make sure my understanding is correct as towing the v-nose at 70 in flat S.C. for example, I would have the tow haul on but utilizing the full 8 speeds? or not? Whereas pulling the camper up a steep grade, I would have tow haul on and 5 gear selected as max?
Would I use tow haul on flat interstate towing the camper at 70 using the overdrive gears or is it best practice to run lower gear, higher rpm, obviously varying gear per conditions.
Thanks all in advance. I know this has been hashed out many times and a lot of it comes with just driving it but I have not towed anything with it yet and just wanted to try and start out on the right foot.
Pete
Pete
