rrb6699
my 1996 ram 1500 overheated. I didn't have a temp sensor wouldn't you know and apparently I need one in case hoses spring a leak.
anyway, I replace both temperature sensors and the crank position sensor. It started up very laboriously with a lot of hissing and the first time it started then subsequent starts seem to go quick was just return of the key.
Now today I take it on a trip to the store and when I come out of the store it doesn't start. I hear a hissing noise when I try to start it and I let it cool down for 30 minutes. I was in the store (a 15min trip) for maybe 10 minutes.
now it truck barely starts - but I can get it running.
I can hear air sucking after it starts and when it runs for 10 seconds then the hissing stops and I seem to be able to drive it. but, if I stop then start it, the same thing happens all over. The hissing is on the right side of the engine. Cant pinpoint it.
Again, what happens is when you start it you can hear the air sucking sound and if you continuously crank it eventually starts up slowly once it gets going the air sucking sound goes away. So, that tells me perhaps when the trucks warm some sort of valve is staying open that should close when you shut off the truck and be closed when you start the vehicle. I think it's remaining open and causing the air to suck in. What would I look for in based on what I have described?
if anyone has solved a similar issue help is appreciated.
rr
rr
