If you just want and additional input you'll need to activate
VehConfig 1 - CHMSL Camera
CBC Features - LED CHMSL Lamp Present
This will give you the Cargo Camera button.
@Mpgrimm2 sells a harness for $20 that you can then use to plug in any RCA camera you choose and have it accessible by pressing the cargo camera button.
Does that answer your question?
Normally when you activate this it then gives you the reverse as well correct ? But only when you have the cargo cam , or at least that’s what I have seen with others .
