Mirror module
N
nicatine
Surrey BC
1c6rr7lt1hs677819 my vin thanks
N
nicatine
Surrey BC
Hey I just wanna be sure , so all the wiring is just for the fog lights? And is this a step by step tutorial on how to set all this up thanks .
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Thanks,
The part # you need is 68209983AE which can be found here
https://parts.allmoparparts.com/oem-parts/mopar-wiring-front-end-module-68209983ae
This is the complete front end lighting harness. I will send you a code you can use if interested.
-Benny
My apologies this is not correct. Please follow the instructions found on Mpgrimm2's post here as the harness he lists is correct https://parts.allmoparparts.com/oem-parts/mopar-wire-harness-68197065aa
Thanks,
Benny
Kyle31982
Cincinnati
Looking to upgrade my 2016 Ram 2500 with power folding tow mirrors. I currently have Manual tow mirrors with turn signals, puddle lights and heat. Can anyone help me with the right part numbers for the switch and door modules I would need? I saw several posts about 1500 part numbers but didn’t see any for 2500 not sure if they would be different or not.
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Sure Kyle here you go
Switch 56046826AE
Modules 68286791AA
68286790AA
Please let me know if you have any other questions.
Thanks,
-Benny
madtrucker2016
New York
Thanks , so these are power folding mirror modules ? Just wanna make sure before purchasing them , also they don’t say their power module they just say door module .is that correct?
go to coparts.com and see if they have the stuff first
yadian
I have a ram 2016 1500 slt and it has no motorized mirrors or flashing lights. I would like to put some motorized, someone could help me
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Does this truck have manual locks as well? You may need to change door wiring as well. Can you PM me your VIN so I can check out a few things.
-Benny
JorgeRam19
California
Hello. I own a 2019 Ram 1500 Classic, express model and currently purchased power folding mirrors, which include the turn signals and puddle lights. What door modules would I need to make these features work on my truck?
thank you in advance!
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Hi Jorge,
Are they Tow mirrors as well? Do you have the switch already?
-Benny
JorgeRam19
California
Hello Benny,
No they are the mirrors that come on the RT Ram. Yes, I purchased the switch with the power folding button.
JorgeRam19
California
Thank you so much!
These would just be replacing the current door modules and all the mirror functions should work, correct?
Anything else I will need?
AllMoparParts.com
- Benny
Preferred Vendor
All
All
You will need to most likely have the sales code LER flashed in for the power fold to work but please check some other threads on the forum as I have heard mixed info. Essentially once you get everything plugged in if the power fold does not work then you will know for sure.
- Benny
JorgeRam19
California
Great, I will do so right now. Thank you for your time and your help!
LuisM
florida
Hi can you help me with the correct door modules and switch to add power folding mirrors to my 2018 3500
3C63RPGL3JG372111
Thank!
LuisM
florida
3C63RPGL3JG372111
Thank!
