I ordered itSomeone makes a delete plate then you can completely remove the bracket too and free up more air flow
I’m just having fun. I have three rams. 2015,2018,2019Oh I know. I removed mine and my temps are drastically better. I’m only running a 190 though and my oil filter relocation dropped my oil temps down about 5-6° more. My oil hardly goes to 203 unless I’m on the highway for an extended period of time.
I ordered it
That's good to know. My coolant temp runs from 198 to 204 currently. Thanks
The highest I’ve seen with ambient temps in the low 90’s is 188That's good to know. My coolant temp runs from 198 to 204 currently. Thanks
Me tooGuide, parts?
I hate unnecessary crap like that
Me too
For performance reasons. No other reasonSo teach me why the AGS need to be removed...thanks!
Cooler temps are the only thing ags delete helps. Less strain on the water pump if you do the v6 fan as well and reduced rotating mass on the engine. Cooler temps are good for tuning. More life out of the water pump And less rotating mass means peppier acceleration with the v6 fanWhat performance is gained?
