Adding illuminated sun visors
Site-r
Lynnwood, Washington
Cummings 6.7
I was able to get the ends from a wrecking yard, and made a harness.
Which map light wires on the center console do I tap into?
HTXRamExp
Houston, TX
The wires to tap into are the yellow with the green stripe and the black wire. The yellow with the purple stripe only works when the door is open.
The vanity lights work great.
Used this info to wire up my sun visor w/ lights, works great, though my wire looked yellow w/ light blue strip instead of green, but either way, no other similarly colored wire.
Site-r
Cummings 6.7
So it seems the 4th gen is yellow with green stripe, and the 5th gen is yellow with light blue stripe.
CS911RSPNDR
STROUDSBURG,PA
Does anyone know the part # for the pigtail connector for the illuminated vanity visors? I need the number for the female connection. My upgraded visors have the male side. I want to build a harness for them.
Thank you in advance.
1Popeye
