Stefan N
Ebay sellers looks like a way, but $18 for a filter and $26 for shipping and tax on that. will find a better way or go FRAM Ultra XG10060 from RockautoSo you cant get RP oil? No big loss anyhow, just curious.
Question for everyone:
What should you do if you think your motor oil has Corona Virus?
Stop thinking to much?
Propoxylated, Aminated versus polyetheramine better known as PEA. So the clear bottle was old Amsoil that was a PEA additive, the new bottle late 2018 not only changed packaging but the formula to 25-50% Propoxylated, Aminated which seems to be an alcohol. How about you amsoil guys get some info from amsoil inc and see what's the deal on this?
pdf amsoil PI
Go buy an emotional support tool or toy. Problem solvedOK, I feel my motor oil has the virus. What do I do?
I wouldn't over think it. Moving to an Alcohol makes it more water soluble which does help many of the additive packs work well with ethanol blends to remove water as well as clean. As more and more parts of the country move to E10-E15 you'll want what ever additive you're using to be able to pull water out so I'd consider it a win.
With diesel fuel, you don't want an additive that absorbs the water and takes it with it into fuel system. HPFP nowadays are pushing 30K psi, definitely don't want water going through them.Some new warnings, clearly this boosts alcohol levels..
- Safe for use with catalytic converters, oxygen sensors, oxygenated gas and up to 15 percent ethanol blended gas.
- Do not use with diesel or E85 fuel or two-stroke engines.
