Uncle Tony SPEAKS on cam and lifter failure in 5.7 hemi
chrisbh17
I suppose its quite possible that the lubrication system works fine *as long as there is little to no sludge*. The oil maybe ends up where its intended because the drips and drops "go the right way" as long as there is a clear path. But once a piece of dirt or sludge ends up in just the right place, that stops working.
So, a high quality, high detergent oil changed at good intervals may very well keep the engine running forever.
RL leaves behind moly which is great, but we also know it has VERY good cleaning abilities. Maybe THAT'S what silences the tick first, the detergents and moly keeps the tick away.
Thanks for making this is a sticky...
TheEnder
4.7L V8
My wife had a 4.7 grand Cherokee absolute junk (we had a 4.0 GC before that, sounded like a tractor lol) it’s the whole reason I went to the Acura MDX for her. At 50k the thing was DONE it spent more time in the shop and the stupid 7/75 warranty was a joke- stuff like the oil steering failing but an o ring in the oil steering is considered a wear item so it’s not covered. my dad’s magnum threw a rod at 90k due to the oil pump getting clogged and we changed the oil every 3k!
so im glad you have had good luck with your 4.7 but I’ll take my chances with the hemi and never own anything magnum
I’ll bet serious money that was a pre 08 4.7.
Sent from my Blue Onyx RAM 1500
seabrook
seabrook
Black 2018 Night
5.7 3.92 anti slip
Now that makes perfect sense there! That does explain why redline would work!
Nells426
Binghamton,NY
So does this tick happen even when driving, or even after it is warmed up? Mine only has a slight tick upon start-up and goes away after a few minutes. I will be switching to Redline regardless
Two hemi ticks, sadly they can happen under same circumstances. Lifter tick can happen at start up with dry lifters, but exhaust tick can happen at start up because the exhaust mani's are cold, when they are hot they expand, when they are cold they retract and this can have issues with seals, plus many times bolts break and air gets through.
A real good way to see if it is lifter tick is at warm idle, if it is ticking then it almost always is lifter tick. The formula in redline does guard against both lifter ticks, cold start up tick and warm idle tick, but obviously does nothing for exhaust. It is a fair number of hemis that will have either issue, it seams to be about 50/50. If after your oil change there is zero difference in the tick, look hard at exhaust.
RVGuy
Alberta, Canada
I finally got a chance to listen to this with the sound up, glad to hear he's basically saying what I've been speculating for years now. Glad I've been driving in a way where my engine is almost never below 1500rpm this whole time, I always figured just putting along at barely above idle was bad for it. I've also been meticulously not idling, I don't warm the truck up for more than a few minutes, I don't do drive throughs, I'll take the long way around to avoid stop lights if I need to go to town.
Honestly, between the Hemi and GM engines eating cams and lifters I'm pretty much done with V8 engines after this truck. They've just ruined them trying to milk as much fuel economy as they can out of them, which isn't even their fault it's the EPA.
I hope they bring the Dakota back in the next while, that's pretty much all I need in a truck nowadays. The Pentastar in a midsize truck would be ideal.
reece
Fraziers Bottom WV
I have 2012 with 5.7 with the "tic". I had figured out that it was prevelent at low RPM. Your findings are outstanding!!. Thank you. Been told many theorys about this problem.
The ECO mode also seems to create the tic ( presuming because of the lower RPM.) I have used the manual shift to keep RPMs up to solve the tic on winding roads. Now I know why that works. My question, can the ECO mode be programmed out ? I really appreciate your effort on this. I planned to tear down and clean lifters this fall. Would have been wasted time.
Jtblackram
Jtblackram
Long Island
I believe that while your in the “manual” mode, it disables the cylinder deactivation (eco mode)
Dodge 1500 4X4
Rochester, NY
Question, Is MDS active on engine start up, does it startup on all 8 cyl just wondering.
RedneckHippy
Washington
2019 Ram 3500 Tradesman
6.4 Hemi w/ MDS
I’m pretty sure it lets the truck warm up before MDS comes on, I don’t typically see it on at all until I l’ve driven for a minute or two. Also I think it doesn’t allow MDS while idling or in park. Look for the ECO light on your dash.
ripping r
Old&Grumpy
earth
6.4 HEMI
I wounder if aftermarket blocks would have changed this set up?
i would thing if this was really the problem engine builders would just make a better block. not us back yard guys but the big boys.
Blstrick55
Everywhere
Back when I had my Hemi charger and was on LXforums they used to have live chats with SRT Engineers. Not sure if they still do but I would be interested to hear what they have to say about this.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
they’re hiding in the quality analysis-warranty rework area for eternity because people keep purchasing.
Tom8
Utah
I run 5-20 synthetic and it is silent. My drive to work is 80 miles RT with almost no city driving. Also for some reason not all of them tick and some model years are more prone to the problem.
Right, I run the same I don't hear any ticks. But like I mentioned before too, I tow a lot so the rpm happens to be pretty high then normal.
RedneckHippy
Washington
6.4 Hemi w/ MDS
I don’t know if there is anything to this, but it seems like the guys putting 300k miles on their hemis are working the snot out of them, and towing almost full time, so maybe working them hard keeps them alive.
Tom8
Utah
So stop babying it. Lol
