Well, I have found a further improvement for my drone issues. Note I said improvement not 100% solution. But, I'm pretty happy how it turned out. I did more research last night & came across a post where a guy had a van with bad drone & says he solved his problem after banging his exhaust pipe in various spots until he found a spot that sounded different & rang a bit. Then he put some kind of rubber piece around it and clamped it & claimed it was gone. I was sceptical..but interested. I'm high on problem solving/have lots of time/have little money so found a chunk of 1/2" wide rubber gasket & plastic zip ties & my hammer & damned if that chunk of pipe just after the crossover posts the cats doesn't ring. Like for 2-3 seconds..vs a dull thud elsewhere. And the ring is at the crossover as well. So I put on that gasket & hit the pipe in that area & the crossover pipe. No ring! And hit the highway. Ok, the drone is still there. But its changed. A) The volume of it has reduced B) Where yesterday it was solid from 1500 to 2000 rpm, now its next almost gone except from about 1700-1800 rpm!
So off to Canadian tire I go and buy a fiberglass stove gasket kit. 3/8" rope x 6 ft and 2 stainless 4" dryer clamps for less than $14 canadian and 10 minutes later, done. (See pic below)
Off to the highway again. About the same result as the temp rubber gasket but a bonus now. I notice on startup & driving around town, the tone has improved! There's a deeper note to it I've not heard before. And I like it! That rope btw is guaranteed up to 1000F so I'm not concerned about burning it up. I picked up that trick using it to wrap baffles on my motorbike exhausts to modify a barky exhaust tone that was hard on the ears.
Sent from my SM-N960W using Tapatalk
