4eyedconekiller
Guys, I'm looking to remove the current ICI Magnum drop steps I have on the truck for some power boards.
I've glanced at several, but figured I'd poll the crew here, see who had what, and go from there. I'm looking at them because everything else that tucks closer to the truck is also harder to use by my grandmother and my two small nieces. They don't get into it often, but I don't want to risk a fall (isn't that a valiant enough justification?). $1500 now is better than a hospital visit!
https://www.customwheeloffset.com/s...019-ram-1500-classic10-18-dodge-ram-2500-3500
-Love the fact that they will be out of sight when up, and have a history - some good, some bad.
-The XL versions look clunky when up
https://www.amazon.com/Aries-304791...8-16227------------&vehicleName=2014+Ram+1500
-The extended drop and second step seems cool, but it looks like it would be pretty noticeable when up.
-Not a big fan of the magnetic switch design, even if it does leave my OBD port free for my CTS2.
https://www.customwheeloffset.com/s...3-extended-drop-09-18-dodge-ram-1500-crew-cab
- Better price point
- Magnetic switch
- Not sure if I want ROLLING BIG POWER plastered down the side of my truck
- Motors look more robust than the AMP steps
5th Gen MOPAR power boards
- OEM quality
- Similar price point ($12-1500)
- Would have to talk to someone about getting a custom harness made.
- Would need custom wiring.
Which ones do you guys have? Which ones work best for you? Any pros/cons?
- Magnetic switch
- OEM quality
