Stockers for almost 2 years and my truck had already around 50k miles when in bought it. Mevotech Supreme which are basically stock replacements for a few months, same with Freedom Offroad stock lenght and now the Claytons set at stock length. You won't go wrong with either choice main difference will be in the bushings and how beefy the arms are if you need such a things so it depends on what you're trying to accomplish. Now that i've been driving with bushings that can flex side to side is that i can appreciate having them as the suspension flexes as it should when it needs and if i need to put the full weight of the truck in the lower control arms i have piece of mind the massive Claytons will take it without a sweat.
Most of the aftermaket like Core, Clayton and the like are built tough so you can have confidence you're paying more for beefier arms and better than stock bushings.
If you have a truck setup for the street Freedom will do well,
If you're into offroad Core and Clayton have better bushings for that mission. Core uses a JJ in one side and some sort of flexy poly bushing on the other, though i'd recommend if you go with Core to get JJ on both sides for the ultimate in strength.
Clayton have Giiro bushings on both sides, or JJ in one side and Giiro in the other and if you ask i'd guess they can put JJ's on both sides. I went with Clayton because i wanted the benefits from their Giiro bushings. i'm more into overlanding so i wanted longevity and maintenace free like the stockers so things like mud, dirt,snow won't contaminate the assembly. Eventually the bushings need to be replaced but i had 50k miles of trouble free miles in my Jeep equipped with Synergy arms with DDB's and before i sold it i was a happy camper , i'm expecting the same from this Giiro bushings, big plus since my rear is loaded with 500lbs at all times and when i go to the desert and beat the crap out of the truck i like the confidence in torquing down rear control arms bolts at the 200lbs factory specs.
If you go with JJ's they have proven to flex well, and they can withstand a lot of offroad abuse. Cool thing about JJ's is that they can be rebuilt/serviced when needed, sometimes than can be a little often depending on the conditions they have live in so greasing those zerks is really important for longevity.
With Giiro bushings you have to press a new one when needed. Both are cheap, Giiros or DDB's have been around for less time but they seem to be proven themselves in the overlanding community again because of their design: free pivoting, self centering, self lubricating, zero maintnenace. etc installing a set couldn't be easier as you don't have to worry much about the angle of the head, the bushing doesn't get smushed if you torque it to King Kong specs as they're made to take the torque (In Clayton's case they're made for the Jeep JT which borrowed their control arms from our 4th gen truck so Clayton designed the bushing counting on those high torque specs in mind, JT is 190ft/lbs, RAM is 200ft/lbs).
https://www.claytonoffroad.com/news/overland-plus-days-compromise-are-over
Again, good luck with whatever you choose. i don't think you can go wrong with either choice. Anything is better than stock, but stockers are not a bad option if you just need a truck to do work as the factory intended for example. If you're looking into offroad, overlanding, 1/4 mile racing, or just want the look of beefier arms the aftermarket has specific choices to meet those demands.
Have fun.
