Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I did the 2/5 drop with springs in the front and flip kit in rear. The shop could not align the truck properly. the top of the tires are bowed inwards. Can anyone give me some pointers?
Here Moog Alignment Caster / Camber Kit. With this kit you can adjust your Camber Plus or Minus 1 Degrees; Caster Plus or Minus 1-1/2 Degree(s). I had to put this on my 2wd 03 with a 2 inches dropped on the front.
Also with that drop you'll want to get those bump stops out of there.
