John judd
So in need of transmission knowledge please. I just had to swap out my OD (overdrive) case housing in my 98 ram with a 47re. I broke the case housing and had to pick up another from a scrap yard. Took the guts out of mine and put them into the new case since the case I got came from a 46re. I got everything back together, got 4 quarts of ATF +4 in it when I noticed that the gear shift does not click as I am shifting threw the gears and the truck goes into gear but is really sluggish most of the time in Reverse and drive and will not go into 3rd at all. At times it will set me into the back seat on some shifts, but mostly it just sputters up to speed. I did not have these issues before removing the old OD but now I do. WHAT DID I MESS UP, I am not a transmission guy and had my apprehensions to doing the work my self. Can someone please help me figure it out.
