Pedal2metal
I replaced all 8 gauge cluster bulbs and still have very dim cluster. I’m getting 12 volts through the fuse when light switch is turned to bright. I thought maybe it’s a bad ground but the gauges work and it appears they share the same ground. The high beam indicator is bright as well.
86 D100
86 D100
