PoMansRam
- Joined
- Apr 30, 2018
- Posts
- 2,089
- Reaction score
- 2,549
- Location
- East Aurora NY
- Ram Year
- 2019
- Engine
- Hemi
Good grief! I think the same dude that torques on factory oil filters also puts all his might into the bolts that hold the rear seat to the floor!
First I didn't have an 18mm socket for the bolts for what ever reason. The socket sets I have all jump from 17 to 19mm. I have an 18mm open end wrench, but that ain't gonna cut it for this job. Luckily Napa had an 18mm 3/8" socket for $3. LOL
I needed a 24" breaker bar to get all 4 bolts moving, then was able to transition to a 3/8" ratchet with a cheater pipe on it. They come out HARD the whole way.
Once the bolts are out. Simply lift up on each side of the seat to lift it off the latches. Trim the metal tabs with a hack saw just to the plastic guide. Reinstall and done. The only workout here is removing the 4 bolts. Screw the loctite. I never seized them on re-install. They went in like butta and that's the way they shall stay.
The major reason I wanted the rear seatback to fold is so I can keep an eye on water leaks and get at the rear cab vents should I need to. Also makes for easy rear window cleaning.
