Josh22855
A forum member had asked me to post the cost of my recent build, here are the numbers...I am sure I am leaving out a few odds and ends...
D-1sc procharger kit $7000
397 stroker kit. $2700
JBA LT headers and Y pipe $1000
Bore/deck block $1000
221/238 cam $725
2800 stall converter $700
Fic1000 injectors $630
Heads ported $600
True trac $ 600
Beehive springs $489
Ati super damper $429
Rocker stabilizers $340
5 layer head gaskets $253
Exhaust cutout and valve $200
Dw400 fuel pump $200
3.4" coated procharger pulley$200
Afr gauge $185
Boost gauge $ 170
Arp main studs $150
Windage tray $140 (had to modify also)
Replacement piston $115
Arp head bolts $110
Crank sprocket spacer $ 55
$ 17,991 is a good ballpark # for the build.
221/238 cam $725
Heads ported $600
True trac $ 600
Afr gauge $185
Boost gauge $ 170
Arp main studs $150
Arp head bolts $110
