PW Locker Problem Data Compilation
Overlander
Oregon
2021 75th Aniv Build #0006
I'm a data guy IRL (application developer/DBA). There have been a number of posts regarding axle locker issues so I figured I'd do a little charting to give some perspective of the issue.
I'll update the second post with the data as it accrues. For now, please post up your status - whether you have a problem or not! We want both the good and the bad for this to be a representative sample. Though, it will never be statistically accurate as this user base is canted; we have both enthusiasts and those coming here specifically looking for a solution to a problem. So this data will likely read high compared to the actual rate in the wild.
These are the minimum fields I'd like to collect. I'm completely open to add others. And the analytic fields will definitely be expanded as the dataset grows. This just a sample and will be revised.
Overlander
Overlander
Oregon
Reserved for data charting.
wobly
Colorado Springs, CO
2021 Ram 2500 Power Wagon
I think this is a great idea! Of course, I am not the one doing the work, I am just an interested, potential Power Wagon buyer.
I think you could add a column for Rebel/ Power Wagon/ Anything-else-that-uses-electronic-lockers. Also, a column for recurrence since i have read a couple of people saying "it's fixed!" only to update their post a few months later saying "It threw an error again".
SkeeterBait
The Birthplace Town of the "Jersey Devil"
At 3000 miles on the 2020 odometer, the locking function has been getting better with use. The rear axle is nearly immediate and the front is improving with small "wiggle" turns. No error messages yet.
LeesEvoX
Houston, TX
Hemi 6.4l
Yeah.. so this is your time, so you can obviously do as you please. But i dont think there are that many issues with the rear locking system. you will hear about them on this site because thats what most people do.. Sign up to a forum to complain about issues, or ask for advice to fix said issue.
Isnt this same system used across the board for FCA products? including the rubicons?
Anyway.
2020 PW, right at 24,000 miles. No issues whatsoever.
Keep your fluid, and magnets clean. USE your lockers. best way to keep things operational IMO
retired
montana
Anyway.
The jeep system is made by dana corp, the ram by american axle manufacturing.
retired
montana
2020 6000 miles no issues but have only engaged them a handful of times.
Gamedog
State #38
2019 PW
392 c.i.
2019 34,*** miles. No issues with engaging lockers, issues with blinking "Axle Unlock" light in cold weather conditions in both 2WD & 4WD when lockers are unlocked. Serviced both front & rear diffs at 30,000 miles & cleaned magnets as it was believed this would remedy the issue, however it did not.
Dealer trip likely.
tjbrowder
Houston
6.4L
As my other post notes, 2021 75A with service lockers starting at 250 miles. At dealership now for diagnoses.
LeesEvoX
Houston, TX
Hemi 6.4l
Thanks for confirming this. I was under the assumption the electronics would be the same
Adventurebound
Las Vegas
2020 3,800 miles lockers work as designed. Used front and rear several times....now if my fancy 12" radio screen would just stop locking up...but that's a story for another thread.
jmt82331
TX
2020 3,000 miles. Have used lockers multiple times with no issues. Thanks
RamCares
n/a
n/a
Dealer trip likely.
Hi guys!
I saw that you may be working with your Ram dealers to get your concerns properly diagnosed and addressed. Please feel free to keep us updated on your progress and do not hesitate to reach out if you need additional support while working alongside your dealer. Thanks a ton!
Courtney
Ram Cares
tjbrowder
Houston
6.4L
Hi guys!
I saw that you are both working with your Ram dealers to get your concerns properly diagnosed and addressed. Please feel free to keep us updated on your progress and do not hesitate to reach out if you need additional support while working alongside your dealer. Thanks a ton!
Courtney
Ram Cares
Appreciate you reaching out, and will definitely keep you posted on the situation.
RamCares
n/a
n/a
Hi, I'm sorry to hear this. Please let me know if you plan on visiting a dealership for this concern. I would be happy to open a case for you.
Alison
Ram Cares
Udy2554
Naples, NY
2018, 19,000+miles! Some “slow to engage” instances, but haven’t failed yet! Not a lot of usage, but I do “exercise” them every so often!
Preparing to service the differentials soon!
amdwilsns01
