My 1979 H-D FXS
Likely looked like this when it was original
When i bought it, it had been changed a bit & it had a Weber Carburetor sticking way out from where this unit sits & had more chrome on the engine than in this image & it had a Ridged Frame
I bought it & had a friend customize it
He began by cutting the Ridged frame off, from the battery back & at some point he cut the neck off & kicked the neck out about 6"
I found damaged Wide Glide front end & it was sent to Los Angeles to a shop to get it straightened out.
He worked on designing a new rear section that he could bolt a Harley Trike rear end to.
We found a 1950s trike rear end with 1 bent rear axle, I located a straight axle for it.
That is when we found out that it needed rear brakes, believe it or not, Harley had used
1948 thru 1963 Willys Jeeps Brakes on the Harley Davidson Servi-Cars
Anyway, when the trike was finished
