Fix a flat
Sean McGillicuddy
Easton Mass.
I have this annoying slow leak that falls under we can't fix that crap!
I have to add 10lbs daily less on warmer days..
we do not want to buy a new tire.... we want to run these crap tires untill we can get new ones in the spring..
Would fix a flat kind of fix that slowww leak ?
Daw14
I have had success in the past with it. A hard maybe.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
There's no such thing as a leak that can't be found. Fix-a-flat is not for long term use. It's also a headache for anyone who ever has to work on that tire/rim in the future. It makes a real mess, and I won't use it unless it's an emergency situation. If you aren't getting answers from the tire shop you took it to, take it to another tire shop. 10 lb/per day leak is not too slow for a competent tire man to locate.
Treburkulosis
Your High End Detailer
Haslet, TX
Where is the leak coming from, I know a lot of shops wont touch it if its in the sidewall or near the outer edges of the tread. They can be fixed trust me. Its just finding a shop that will and basically you have to say there is no warranty and they are responsible for a blow out. I personally wouldn't put slime or fix a flat in it.
BadHemi2014
Greater Cincinnati area
Could be a leaky valve stem too, fix a flat won't help that, but should be a fast cheap fix for any tire place even a chain store.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
You're right about the valve stem.
Reputable tire shops don't use fix-a-flat. I haven't ever seen one that does, and I'd stay away from any that do. Like I already said, fix-a-flat isn't intended to be a permanent fix. The instructions even say this...
Tripper
Wichita, KS
i've used fix a flat on all sorts of tires with no problem. If you just want to run it for a few thousand miles I see no issue.
BadHemi2014
Just to clarify, I meant replacing the valve stem should be a cheap and quick repair that any tire shop can perform. If that's the problem of course.
Warm water & soap is what a good tire shop will use to see the bubbles
& then the leak is easy to find
The leak must be in the tread of the tire, or the valve stem/ TPMS valve
Tire shops get really irritated with emergency tire sealant, but some times a quick fix is needed.
When was the last time that a tire shop aired up your spare tire
Auto manufacturers are beginning to delete the spare tire & just put a patch kit & a cheap air compressor in the vehicle
drakon543
pa
find someone who has a small pool and put the whole tire in to find the leak. big one for me most tire shops tend to not try to fix is the rims sealing surface. as it generally requires running some kind of abrasive across it which will fix the leak but will also remove more of your rims coating.
stomp
Norwich
Mine ended up being a cracked rim. Also fix-a-flat can screw with the TPM.
fulltimerart
Florida Panhandle
Make sure you replace the valve cap too. Have they checked the entire rim too, I have heard of a porous spot in the metal. Just my 2 cent. Art
Scott0700
Rexford, NY
If you do go the fix a flat route be sure to tell anyone that works on it in the future. It can create an explosion hazard.
Marshall
Sk, Canada
2014 sport
If you have to add 10 lbs /day, that is not a slow leak. Find a real tire shop . someone don't know what hell they are doing
redvetram
Idaho
Pentastar V6 3.7
I’d be interested in knowing why they say it can’t be fixed. Like others mentioned, maybe take it to another shop. I’ve had “slow leaks” before, but we’re talking having to add 10#/month, not daily. I guess if your tread is really good and the tire is otherwise structurally sound, the other option is to have them put in an inner tube. I’ve done this with all my ATV tires that develop slow leaks but still have decent tread. I get an extra year or two out of them. Don’t know if the added weight of the tube changes the balance or driveability of a full size truck running hwy speeds, but worth checking.
tron67j
Maryland
Another vote no for fix a flat gunk. Good to get you out of trouble if no other option, but it is short term fix with potential long term problems. A reputable tire shop will find the leak. Good luck
