Thuren rear coil ride height
JamesgPW
Orange County
Has any one found or know of a chart approximating the Thuren rear coil ride heights under various weights?
Roman2468
Red Lion, PA
Hemi 6.4l
This is his photos of Thuren front coils with OEM and Carli in the rear.
RAZ175
Colorado
2016 Power Wagon
6.4L
I just got finished installing front and rear Thuren springs. Weight in my bed is around 600-700 pounds (fiberglass canopy, Decked unit and tools). I had 1/2" of sag with that weight on the factory springs. After I put on the Thuren springs, the rear came out to be the exact same height, so no additional sag with that weight. Not sure what would happen with a trailer attached. Even though the Thuren springs might be softer, they start out longer than the factory springs by about one coil..
JamesgPW
JamesgPW
Orange County
Did you use 1.5” or 0.5” up front?
RAZ175
Colorado
2016 Power Wagon
6.4L
I used the .5" up front as I already had .5" sag on the factory springs and was concerned that the Thuren would sag more than they did. I did put a 1" spacer in the rear for a little bit of rake.
Wu tang
Reno, NV
I’ll be going with the carli r2 this spring. Increased payload and smoother ride.
Already have the Thuren .5 on the front.
JamesgPW
JamesgPW
Orange County
That is the build I’m looking at. I have about +300 lbs of sliders and skids on, +100lbs Dethloff bed rack and +300lbs of recovery gear in the bed. I really want to do the 1.5” up front and stock height Thuren rear coils with a 1” spacer but I am afraid I will be nose up with zero rake. I’d like about 0.5” to 0.75” rake.
RAZ175
Colorado
2016 Power Wagon
6.4L
With the 1" spacer, I have 1.5" of rake. If I had used the 1.5" front springs I would only have .5 " of rake which would go down quickly when I really load the back end of the truck.
Britome
Cincinnati
6.4 hemi
Very helpful thread. I'm trying to get my rear end sag gone. My overland setup woth decked system, leitner, fridge, etc is a bit too much. Beem considering airbags even though I know it compromises articulation
Bobram1500
