ChuckL333
I've had this truck for two years now, and since the day I picked it up it's had a misfire on cyl 1. Never bothered to dig into it until now, as it has been easy to avoid. Now I'm looking to haul a few things around that's changed and getting it fixed has moved up on my priorities.
So since getting the truck (09' Ram with a 5.7) Ive put 30k miles on it. The misfire only happens under 1/2 - 3/4 load. When it happens the light flashes and goes out. Can feel the misfire slightly without a ton of loss of power, can mostly hear it. Parking the truck, turning it off then on always fixes the misfire and I can continue to drive like normal. Misfire is very easy to replicate by using more throttle. Everytime I've checked the codes I've gotten P301 cyl 1 misfire.
So far I've swapped coils, changed plugs and put a new injector in cyl 1. Compression test was perfect.
I'm not super mechanically inclined but I like to do as much as I can on my own. What should I start looking into next? I'm afraid it might be lifters. Find it hard to believe though considering it goes away just by restarting the truck and I've put 30k on it.
Truck is currently sitting at 230k miles.
