killymcgee
Helping a friend work on a 2012. Both CV shaft retention clips/rings and the o rings are gone on his front diff. The CV shafts are pretty loose but no damage to the diff. We're swapping CV shafts (busted boot) and I can't find the retaining clips and o rings that show to go on the stub shaft.
Also the 4 wire plug that goes on the front locker? on the front diff (passenger side) is damaged and I need to replace the harness connector.
Anyone have a part number or source for these parts?
