North Edition Leveling Kit?
Bcryan
Syracuse
Has anyone done a level on a North Edition? It comes with a factory 1”lift and all the shops I have talked to say it doesn’t work with a standard leveling kit.
SOSBOURN
Katy, TX
Following thread, I have a 2019 North Edition and wanting to level it out and add some bigger tires once the original tires are worn.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
I have not had a North Edition at my shop yet but I would think it’s similar to the warlock that came with the factory 1”. Can you post a couple front end suspension pictures
Bcryan
Bcryan
Syracuse
Let me know if you need a better angle.. I’ll have to take the fender well off in the back if you need a better angle on it
Bcryan
Bcryan
Syracuse
I'm not an expert on this, put I currently have a 2019 Laramie with the 4X4 Off-Road package, which is suppose to be the same as the 1" factory Rebel lift. The difference I"m told is the Rebel has Bilstein shocks and the Off-Road package has Mopar branded Tempco HD shocks In two weeks I'm having the local 4-Wheel shop put on a DayStar lift that raises the front 2.5" and the rear 1.0" They have this exact set-up on the owners
that is the only info I can find
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Maldiny19
MD
you can do any leveling kit you’d like. There is nothing special as I suspected it’s the same set up as the warlocks 1” higher than factory.
@Quick_Shifter - The Truck above has the same suspension (north edition) suspension as mine. Will the FOX 2.0 kit setup work on this? and is that still what you would recommend for the best ride quality? I am looking for 2-3" lift from where she currently sits with seems to be 1" lift from factory.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
It’s 100% the orp package. Fox 2.0 is a Great riding coil over. It can be dialed into gain 2+ inches but if you want to go 3” I would step up to the Fox 2.5. IMO I would just go straight to a 6” lift because 99% of guys that want 3” end up wanting a full lift. So I would recommend skipping the leveling kit and going straight to lift
