Lifted 4th Gen Pics - Show Em Off!
lokes_treachery
Canada
5.7 L HEMI
Thanks! I love this truck.
Wow looking dialed in! I just ordered a Rambar as well for my Classic Tradesman. Did you have to modify much to make yours fit nicely? Asking since the Rambar isn't supposed to fit a 1500 Classic...
j-b
Kansas City
Thanks! I appreciate that. So I'm not sure how many different models of Rambar are out there. I know when I looked up the install instructions it looked a little different than this one. Mine came off a TRX from the factory.
I had to cut off some welded washers on the underside and some of the tab on the inner bed mounting bracket.
I also had to make some adjustments to the top bars to get the width right.
But as long as you have a cut off wheel, install should be a breeze.
healthyrx
Oviedo FL
2017 1500 Sport Night
Lift is finally "done"
- Eibach pro truck lift with rings at 2nd slot
- RC 1/2" top plate spacers in the front
- Zone UCAs
- 315/70r17 cooper discoverer st maxx
- 17x9 procomp 32 wheels with -6mm offset
- lug nuts and 77.8 to 108 mm hub centric rings
I have a zone 1.5" body lift I may still be installing at some point when I can get a long weekend I dont need to drive since this is my only vehicle
After the lift was installed I was on stock tires for about a week and fender measurements on stock tires were ~36/40 inches F/R before and 39.5/41.5 F/R after. Havent measured with new tires on yet
Note- front wheel is slightly turned from backing in so it may look "off" in the pics
Bone Stock
Lifted on stock tires/wheels
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
- Zone UCAs
View attachment 481642View attachment 481643
Bone Stock
Awesome Job!!!!! Truck looks GREAT
j-b
Kansas City
- Zone UCAs
Bone Stock
That looks really good!
64on37s
Oregon
2016 2500 6.4 4x4 with 4.10 gears on a 5 1/2” BDS Radius arm lift with fox shocks. Full Badge and chrome delete, 10 % tint front and over factory rear windows, 50% full windshield tint with 5% curved brow. 6500k HID headlights and full LED swap throughout. Moto metal M0970 20x10 -24 wheels currently wrapped in a 37/13.50 Maxxis Razr MT, K&N CAI, magnaflow muffler with resonator delete and dumped 5” tip kept high and tight so it’s unseen at rear axle.
