Northstarab
I RAM Limited is a 2016 with the God forsaken air ride suspension. Works great in the summer but once winter hits MN it goes to hell. 1st 3 years were fine then in the winter of 2020 when it gets below zero which it does on a regular basis up here in MN the rear collapses on itself. When I start the truck it will raise to normal operating position and all was good. 2021 does the same but half hour into a 3 hr drive the rear collapses again and there is no fix. Cattle truck with no rear suspension. Of course out of warranty, now back in my heated garage it decides to work again. I can't be the only one experiencing this issue with the air ride can I? I've checked all lines and bags for leaks, no issues. So am I stuck with a suspension system that won't work as designed when below zero? Never ever again will I buy a truck with air ride. Anyone have any fixes or ideas? RAM of course no help what so ever.
