Acanii headlight issues
Tmc79
Tmc79
Massachusetts
How long are you waiting before testing the changes?
About 15 minutes, the global window down that i did as a test, as well as turn signals set to led worked instantly. As of now I'm convinced its in the headlights. Honestly I could care less about the white drl part. I actually like the look of the amber better. I may do some research on just disconnecting the white portion of the light and keep it just amber, more like the oem configuration
hunterdan
SE PA
2019 classic
When messing with my turns and drl options it took hours for them to reset. No idea why, but it took a while.
