Low profile shark fin antenna
DavinNotDavid
Dallas, Tx
I want to get 37s, But I don’t want to park outside, so I need to find a way to get into my garage. Other than some decorative wood on the actual garage entrance I’m gonna “shave”, I really need to find a low”er”profile radio antenna. Is there such a thing? Willing to relocate the antenna, if there is way to do so. Ideas? Suggestions?
DILLIGAF
Canada
Interior windshield mount. Thats what I after I deleted the antenna.
so the only antenna on your Ram is the roof antenna ?
So the shark fin antenna contains the Sirius/GPS/AM/FM/phone
How tall is the Ram at the highest point, counting the antenna, while on level ground ?
Do you have to enter places like parking garages, what is the clearance at those locations ?
Then shop around for a puck type antenna, you can mount a puck type antenna, on the bottom outside corners of the windshield.
( you would need to repair the hole in the roof )
What function(s) will you have to relocate to another location, like above the radio, but below the dashboard.
What would it cost you to make the changes ?
Is it possible to raise the garage door height ?
Do you own the property ?
brian42
San Diego, CA
I don't remember where I saw it but there was a thread where someone flipped the shark fin and installed it on the roof inside the cab instead of outside on top.
Someone else had a shop move it to the dash:
