How do I measure the lift on my truck?, Insurance won't insure anything with more than 4 inch lift & I don't know how to measure it!!
Lurch Logan
5.7 liter Hemi V8 4x4
I have a 2006 Ram 1500 Mega Cab 4x4 5.7 liter Hemi V8(1st time Ram owner). I just need to know the lift on it for insurance purposes. I can post a pic or measure it myself but I just need to know where to look or start. Btw... I am straight up beginner level,I just need to know from someone who has a lot more knowledge than I do. Any help would be appreciated!!
Fourbynut
Lancaster,PA
Wow never heard of that before, not sure how you would tell other than comparing it to another truck that you know the lift amount.
usaf2006
Augusta, GA
Have you shopped around for insurance? They've never asked about mine before, geico, AAA, USAA.
John Jensen
San Diego County
Ecodiesel
Low rate companies who only approve low risk customers will ask and will not insure an altered vehicle.
Some other companies also will not insure an altered vehicle if you declare it, they don't normally ask.
I had to drop a low rate company when I purchased a 4" lifted Jeep. When I sold the Jeep I went back to that same company.
Back to Lurch's question. Any lift installer can probably answer your question.
rick16706
Tucson, AZ
2019 1500 Classic - Warlock
6 Cyl 3.6L
You might want to be careful what you tell an insruance company. I'm a retired cop who's done guite a few traffic accident investigations in my career, and one of the things I learned was that insurance companies spend a lot of time and money trying to get out of paying claims. Many times I've seen where they would refuse to pay a claim because the insured claimed something like driving less than 10 miles each day to work, to get a particular rate, when it was actually like 11 miles or more. Even if the distance driven had nothing at all to do with why the person was filing a claim, the insurance company would refuse the claim.
If the truck is actually stock, then there would be no problem, but if a prior owner had lifted the vehicle then it could result in a claim rejection. Just saying.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Insurance companies will always find something to justify a claim rejection nothing new about that lol ..
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Actual lift height is measured at the bottom edge of the door to the ground on a level surface. You then take that measurement and subtract STOCK measurement height. That will give the actual lift measurement.
To add, this is how my state inspection does it and they have a book of stock height measurements to follow as a standard for the Altered/ Lifted vehicle inspection.
Ole Buck
South Alabama
Then what would one do if they bought a brand new truck from the dealer with an aftermarket lift already installed?
Daw14
Go to the truck on the lot next to the one you just purchased and measure it or a few.
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Umm, I kind of have a similar question. How would I know if my truck has a lift installed if I'm the third owner and didn't ask?
I was crawling around underneath the other day and noticed that between my rear axle and springs there are 3-4 spring width metal spacers. There is about 1-1/12" between the axle and the spring. I always thought it looked like it had a mild lift but I don't have a stock truck twin to compare.
I don't see them in the service manual but that might be a generic picture.
Phillyrube
Flatistan
When I was on the cops we measured from the ground to the bottom of the bumper, or to the frame rail.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Max bumper height is another part of the lifted vehicle inspection but does not designate a vehicles actual lift. Especially with all the aftermarket bumpers out there. Again this is based on laws in my state.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Picture would be easier to follow.
Some factory spring packs, mine for example, come with spacers to get to the factory set height. I moved the spacers from the bottom of the pack to the top, which lowered the back approximately 1.5".
tallfetcher
u.s.
5.7L
as a safety inspector in my state i can say that we measure them much the same way that 18CrewDually has mentioned. and just like his truck mine with the factory suspension has spacers under the springs in the rear and a factory leveling kit that raises the front end 2". I had to look at the build sheet to find that out. Easiest way to measure your lift is to measure from bottom of door to ground or top of the wheel well to ground and compare to a truck that you know is not lifted. Or you can take it to somewhere that installs lift kits and ask them to look at it!
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
I'm only interested in case I want to add something like a sway bar and the manufacturer has one for lifted trucks that's different from the others.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
That is typical from factory.
I moved the 2 that you see on the top from the bottom to lower the back so it is closer to level. Mine use to look like yours. This has no effect on sway bar or the mounts.
