Bilsteins set at 2.8: Post your pictures!
augiedoggy
western NY
3.0 Ecodiesel
Do you have any rake? Hard to tell by the photo. Doing this mod this spring and need 1” of rake due to me towing a 20’ bass boat.
I used these with my Bilstein 5100s and still have a bit of rake. https://superlift.com/product-detai...993FT4MlCtf-IrJJ-uPfMuwXSibA9b1RoCKOUQAvD_BwE
full disclosure, im getting closer to 3" of lift out of my 5100s due to the previous struts I removed having the factory spring, but aftermarket lower perch that sits higher on the bilstein retainer ring.. I have my shocks adjusted to 2.1 because with it set to 2.8 I had like 4" of lift which messed up other component geometry. the tires are 295/70/18 although I just yesterday swapped to 4ply nitto G2's in the same size for better ride and mileage. (20lbs less per tire)20211025_100652.jpg
IDSandman
Idaho
full disclosure, im getting closer to 3" of lift out of my 5100s due to the previous struts I removed having the factory spring, but aftermarket lower perch that sits higher on the bilstein retainer ring.. I have my shocks adjusted to 2.1 because with it set to 2.8 I had like 4" of lift which messed up other component geometry. the tires are 295/70/18 although I just yesterday swapped to 4ply nitto G2's in the same size for better ride and mileage. (20lbs less per tire)View attachment 482738
Thanks augie!
1Popeye
