buckeyexx
Ohio
2016 Power Wagon
Installed new led low beam bulbs to replace the ****** halogen bulbs. We will see how well they do but they have to be better as long as they hold up.
Ken Camp
Northwest PA
3.6L Pentastar VVT V6
Haven't had a chance to drive my 2018 in real good snow since I bought it in October, so had to take it out for a drive in good old fashion snow storm (1st good snow in years, 14 inches) and it did great. Now to get all the filth cleaned off it LOL.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
After our last big snowstorm I noticed snow was getting in my box via the tailgate and I can’t stand that so I added a tailgate seal kit. Don’t mind the crooked section that runs along the bottom, I straightened that part out.
I'm with you keeping water out. I found that if you go to your local Harley Davidson Dealer and get these rubber plugs they fit perfect in the stake pocket holes.
SOLID PLUGS ABOVE
If you need to run through with a hose or wire for aux fuel tank like I do, they have the one below for that.
Gregdad
Fort St. John BC, Canada
ClassicJoe
NC
I drove to the farm and took down bow stands. I also added a Reese three ball hitch.
DanHate
Hi WY-Dave, Do you have any pics of how you tapped into the cigarette wiring? Did you splice into the hot leg and screw the ground to a part of the metal structure in the
Easiest and vest way to tap into any of the cigarette wiring harnesses is to get a T harness. Just unplug the harness from the back if the power point, clip in the T harness on both sides and you are good to go. Hardest part is getting your hand around all the dash nonsense.
WY-Dave
Cheyenne, WY
6.7 CTD
Hi WY-Dave, Do you have any pics of how you tapped into the cigarette wiring? Did you splice into the hot leg and screw the ground to a part of the metal structure in the dash?
Since I was there, I tapped into both
