Dusty
- Joined
- Jun 6, 2013
- Posts
- 1,223
- Reaction score
- 1,262
- Location
- Rochester, New York
- Ram Year
- 2019
- Engine
- 5.7 Hemi
Sure didn't. Over the years I've encountered a number of over filled engines, but the majority were only over filled by a quart of oil or less. I can see, depending on the engine, this not causing an observable problem. But once you overfill to the point the rods and crankshaft is dipping into the oil and slinging it around, there is going to be some kind of major issue. Engine oiling systems do not like air bubbles in the oil.Okay, but it certainly didn't run just fine as the previous comment said with 7 extra quarts.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 03 June 2018. Now at: 063727 miles.
