Mister Luck
cassis tutissima virtus
- Joined
- Aug 25, 2020
- Posts
- 1,651
- Reaction score
- 586
- Location
- WEST COAST
- Ram Year
- 2016/2017
- Engine
- 5.7 V8
Yes, I am aware of that. However, I am wondering if the charging voltage going into the battery might be different than those trucks that do not come with AGM.
My RAM is a 2017 and the OEM battery is not AGM
When I changed my battery out I asked the same question and I’ve been looking through settings for the IBS Intelligent Battery Sensor and found the ones applied to my 2016 1500 5.7 are the same as the 2016 2500 6.7 Cummins which tells me they’re probably the same across the board.I worried about this also, I couldn't get the dealer even to tell me if I had ECM code for battery type sensing. So I said screw it and put one in anyway. I haven't boiled it yet - which would be the failure mode (overcharge - AGMs are more efficient so need a lower charge rate).
Intelligent Battery Sensor Readings
I Changed my battery recently and was concerned the battery I replaced the OE battery with is Absorbent Glass Mat ( AGM ) and not , ( FLA ) Flooded Lead Acid but is still the same Group Size Item Number 852241 Group Size H7 (94R) CCA 765 CA 955 Voltage 12 RC 140 Ah 80 Length...
www.ramforum.com
