corneileous
- Joined
- Sep 6, 2016
- Posts
- 6,851
- Reaction score
- 3,916
- Location
- Podunkyville, OK
- Ram Year
- 2018 Ram 1500 Limited 4X4
- Engine
- Hemi 5.7
Then why did you start off with your first post pretty much saying that all of us that have the 392‘s are basically full of crap when we said that the OPs high geared rear end is the problem?I'm not discrediting the 3.92. See this post:
Unhappy with 1500 towing. Need Help
So then tell us…. If what you say is so true It's not "if", it's not my opinion, it's a mathematical certainty. The two trucks have a different tow rating on paper, due to the 3.92 being able to accelerate faster from a dead stop. Two of the J2807 tow rating tests deal specifically with 0...www.ramforum.com
So then again if the high gears and the low gears will yield the same towing results then why have two different ones? Maybe if the OPs truck had the 392 gears he could actually drive the speed limit where it was 65 or 70 without working the heck out of his truck.My entire argument in this thread has been this: the 3.21 and the 3.92 will give you identical towing results at 62 mph (which is what the OP talked about in the very first post) so for the OP, getting a 3.92 will not change or help him at 62 mph.
