There's been a few questions about the intake manifold. I did reuse the stock 5.7l, and it seems to perform fine. One tip for anyone that is pulling their intake manifold, for any reason is to clean, clean, clean the "valley" between where the injectors sit, and the cylinder head. If you don't, I guarantee you will drop dirt/junk down into your cylinder heads. If the valve is open on that cylinder, you know what happens next. I would personally spray with water carefully avoiding the electrical connectors, and them blow out with compressed air. Do this a couple of times till you think it's clean, then do it one more time with brake clean and compressed air.
The torque values for the engine are all readily available, and honestly only two things REALLY need attention in my opinion: The oil pan and the intake manifold. The oil pan should get some form a gasket right where the timing cover seal sits on it. I made sure there was some on the block side as well.
The intake manifold required some google search engine skills to find, apparently it's top secret (kidding). Bottom line, I torqued in three stages to 98 inch/lbs. The bolts also need sealant if you are reusing. I used Permatex thread sealant, in the big white tube. I found one set of instructions that called for 108 inch/lbs, but since I was using liquid sealant (acting as lube) I went with the lower number. As with the oil pan, or anything that's rectangular and critical, start in the center and spiral out to the ends with your torque sequence.
Photos for clarity, but ignore the dust. The truck was already driving at this point , and I had been it a dustbowl at work.
You could call this "The Valley of Instant Regret" if you don't clean it well, back to the firewall on both sides.
