Diagnostic fee
silver surfer
South Brunswick, NJ
So I took my 1500 in for 4 tires and an oil change. I asked them to check for an exhaust leak as I hear a ticking on cold start and RAMs are known for exhaust manifold bolt issues. They wanted a $175 diagnostic fee! For what? To listen for a leak? I'll wait til it goes and then use my MaxCare warranty. I tried to be proactive.
retired
montana
I will only charge you $100 over the phone to listen for the leak and tell you how to proceed.....hmmm money to be made out there lol...
LoadedExpressRam
Gulfport, MS
Chris fix on youtube had a pretty simple method of checking for exhaust leaks. A weak leaf blower and a spray bottle of soap water. Its helped me especially after adding an exhaust cutout. Good luck
Jeepwalker
WI
2012 Reg Cab, 4x4
I was told the same thing one time when the dealer was doing warranty work. Similar dollar-figure as I recall. Heck they were updating a new airbag module had the scan tool already hooked up to the truck! I know they have to make money to pay for their time, but the message I got was, "we really don't want to do it."
I have my own scanner now and can do what I need. Thank you Chrysler ..for pushing me over the edge to get a better scanner!!
PoMansRam
East Aurora NY
I get it that you can't expect a shop to work for free, but please..
Unless the truck is a total rot-box or has aftermarket exhaust manifolds, headers, etc.. All you have to do is see if the heat shields wiggle. If they do, there's broken manifold bolts. That's 30 seconds worth of diagnostics with no tools or equipment needed.
Shops used to "waive" the diag fee if work needed to be done. It basically gets rolled into the bill.
Today when a used Chevy Sonic costs you $23K, all costs go up.
Jeepwalker
WI
2012 Reg Cab, 4x4
In my case I was willing to pay extra for the software check I was asking about (and told that to the service advisor). Anyway, we just left it be.
2020PW
East coast
Skilled labor isn’t cheap, cheap labor isn’t skilled.
SitKneelBend
St. Louis
3.6 Pentastar
The diagnostic fee is typically only applied if you decline repair (at my dealer). My diagnostic fee went up from $149 to $179 at my last visit. Glad I bought an extended warranty (10 years/75,000 miles). Its one of the reasons I let things pile up before going, that way "something" will be fixed under warranty and I'm only out of pocket $100 for the deductible (and the diagnostic fee disappears).
MuleDawg
Tuscaloosa, Alabama
Good for you brother!! I would have told them to also check underneath to see if the glow plugs were glowing…
cashman070
Victoria, BC
Or better yet - your driver side power mirror motor fails won't move in / out - the mirror is covered under warranty however to diagnose it isn't covered - anybody looking at the mirror can see it wasn't working but they have to diagnose it to confirm and this diagnostic charge isn't covered :rolleyes::rolleyes: - so I said then just switch out the mirror but they can't do that without a diagnosis. So I said well if the diagnosis shows a faulty mirror motor then the diagnosis should be covered they said no it isn't -I said I understand if the diagnosis showed something that isn't covered by warranty but the diagnosis showed a warranty issue they said oh well that was the insurance company said - just a stupid way around charging a additional fee
Justin33
I specifically asked them to check two different oil changes and they said no both times you watch them be broken and out of warranty.
indept
South Jersey
What warranty are you referring to, 3/36 or an extended warranty?
SitKneelBend
St. Louis
3.6 Pentastar
I'd find a different dealer. I've never had a diagnostic fee charged if they are also performing the fix.
DaveSharp
Canada
Update: the tech heard the noise on startup and got the MaxCare approval to do the repair (both sides) without the diagnostic fee. A good dealership.
Don't forget to bring him a coffee or what ever. He was a nice guy and did you a favour to save you some money.
njjeff201
Sparta, NJ
5.7 E Torque Hemi
I was thinking of getting a scanner. Which do you recommend? TY
njjeff201
Sparta, NJ
5.7 E Torque Hemi
Looking for an affordable scanner. Any recommendations? Thanx guys
