hunterdan
- Joined
- May 7, 2018
- Posts
- 845
- Reaction score
- 782
- Location
- SE PA
- Ram Year
- 2019 classic
- Engine
- 5.7 Hemi
Just got done installing the total flow 5" exhaust tips. I went with the stainless/chrome, not exactly which they are, but my guess is chrome since the entire tip is finished. Fit and finish is great. They are the same length as oem, maybe a hair shorter so they don't stick out quite as much. Install was easy, only thing that would have made it easier was a grinder with a cutoff wheel to cut the weld on the clamp. I was able to wiggle and break the weld with minimal effort. I used a piece of cardboard from the box to use as a spacer so that I spaced the tips even in the bumper cutout. Overall, definitely worth the $100 or so I paid for them. I had previously contemplated buying 2 weld or clamp on exhaust tips and cutting off the oem tips and welding on new ones. However, you're still looking at almost $50 a piece for a quality 5" exhaust tip. If you're on the fence, get them. Are they carven quality, probably not, but they're still less than half the cost and offer great looks. They're available in the chrome or black version for the same cost.
ram 1500 muffler delete| Dodge Ram 1500 Exhaust Muffler | Dodge Ram 1500 Exhaust | ram 1500 exhaust | ram 1500 direct fit muffler | ram 1500 muffler delete| Dodge Ram 1500 Exhaust Muffler | Dodge Ram 1500 Exhaust | ram 1500 exhaust | ram 1500 direct
ram 1500 muffler delete| Dodge Ram 1500 Exhaust Muffler | Dodge Ram 1500 Exhaust | ram 1500 exhaust | ram 1500 direct fit muffler | ram 1500 muffler delete| Dodge Ram 1500 Exhaust Muffler | Dodge Ram 1500 Exhaust | ram 1500 exhaust | ram 1500 direct fit muffler |
www.totalflowusa.com
