Birchmore213
I recently installed a 4 inch lift on my 19 classic. And I am having issues getting the track bar (panhard bar) to line back up properly. Does anyone have any experience with this and how did you fix it? Please help me!!
While the truck is on the ground have a helper lean on the rear bumper the the direction you need to go. It doesn’t take much force.I recently installed a 4 inch lift on my 19 classic. And I am having issues getting the track bar (panhard bar) to line back up properly. Does anyone have any experience with this and how did you fix it? Please help me!!
This is easily the best method if you're by yourself. Especially if your trackbar is off by quite a bit.I have used a ratchet strap in the past to pull the axle one way or the other.
