Tire PSI reading In the wrong location but correct PSI
Yukon, Oklahoma
I took my truck in to get 2 new tires I told them I wanted the front tires moved to the rear inner and the rear outers To the front But I wanted the new tires to go on front. I don't know how it happened I just need to know how do I reset the the tire PSi So that it reads in the correct location. Because in this picture, The front tires are reading like they are on the rear inner I have checked them and checked them 3 times.
Irishthreeper
When I have my tires rotated same thing happens but after a few miles the correct reading appears. Not sure if your issue is the same as a rotation or not
clifford15
CTD
The inner duals are on a separate signal than the outer s and fronts. They will never update to a new position except for left/right inner rear.
