Yes thanks for the responses, this was up in real winter after a couple hundred miles on unplowed roads during a storm up in the north….Canada below zero. Not in Colorado.
I thought as we get plenty of snow in Colorado and I had driven on unplowed snowy roads there, in what we Coloradans think is cold temps…that I was going to be fine anywhere…. I was wrong. There are no cracks in the airbox, the truck had maybe 7k miles on it. Stock. All the snow and ice was under the air filter in the box. I cleaned it all out and put in a new air filter and things went fine once I got onto some plowed roads again.
I guess the mistake was no front cover. It is my first diesel so still learning. It sure shocked me when I opened up that airbox and saw what was inside
I spend time in Northern Wisconsin/Minnesota in the winters too where -15 F is pretty normal… so I appreciate the Canadians checking in! I gotta get her dialed. Do I need to be worried about the DEF freezing too? The poor truck will be spending maybe 20 nights a year outside and not plugged in to any block heaters…
I’m a little gun shy about next winter…
