Additional UAQ/UAS Update Files 28.3/30.24/34.2
SitKneelBend
St. Louis
3.6 Pentastar
Same here, I am trying to fix my nav as it no longer will load since doing all the updates getting to 39.5, so now doing the 39.6 I want to reload 21.9 map files, but tried all different ways to unzip etc and get the same error. I also tried peazip as well with no luck. Anyone know of a known program to get the 21.9 update to unzip properly in windows 10?
What error are you getting? Can you share the file?
PdPuNOme
Jersey
The file is on the google drive we have access to. I was finally able to unzip it using win7zip. Now trying to figure out why the 39.6 file unzipped will not initiate the update boot on the radio. Anyone else having issues trying to load the 39.6 on the truck?
srtdrew
Pennsylvania
My screen and digitizer have the lovely bubbling/separation issue, so I gave up on upgrade of the software and may just upgrade my truck. Kind of disappointing there's not recall on them at this point with such a glaring defect.
SitKneelBend
St. Louis
3.6 Pentastar
Contact @RamCares . Some have had their radios replaced for this issue even when out of warranty.
PdPuNOme
Jersey
Finally figured out how to unzip the 21.9 file, have to use 7zip and open the archive to then unzip it, anyway now trying to reload the maps but cannot get the radio to react. Anyone else find a way to reload the map files after losing them during an upgrade? I am at the 39.6 version currently and trying to downgrade to the 39.5 with the 21.9 maps it errored out with 01.
There really should be more mentions about UAQ upgraders to add map files surprised no one really talks about it. Given how the AA works 50% of the time whether its the device not supported or simply doesn't acknowledge the plugged in (dozens of cords and 10 different hubs, still same) I need the nav as a backup, I drive all over the East coast and better part of the country regularly so nav is very important.
PdPuNOme
Jersey
Finally worked using 39.5 and the 21.9 map file, restored navigation maps. Now will do again tomorrow to go back upto 39.6 but this time will include the 21.9 map files.
I have seen on jgc forums a 22.5 and other higher updates for maps wonder if ram will get any?
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Please detail exactly how/what you did, unzipped, combined?
Edit:. I bet the jgc nav files would work also since the SW updates appear to be the same
I tried previously with the 22.5 and 22.6 updates unsuccessfully on my parents UAQ & non working nav. Haven't tried with any of the newer updates.
COtto1984
Cummins 6.7
I have P/N 68461699Ax (2020 1500 Classic UAQ 4c Nav) radio that I installed in my 2015 Ram and came with firmware 34.5.0. Any available updates worth upgrading too?
Mpgrimm2
Preferred Vendor
SC
5.7L
v39.6 is the latest
COtto1984
Cummins 6.7
I successfully upgraded P/N 68461699Ax (UAQ 4c Nav) from 34.5.0 to 39.6 via the link posted a few pages back.
Mpgrimm2
Preferred Vendor
SC
5.7L
Has anyone figured out how to get past the Error 20 if you're getting that when attempting to upgrade?
Not sure if it's your issue, Some of the later SW updates, require you to be in application version 22.64.x or higher before going to v39.6.x , etc
