how much oil do i have to use?
j6n69
Haren
5.7L
so before i start i wanna apologize for my english.i need your help, my dad gave me the task to find out how much oil we have to put in the car.i searched so many websites but i could just find the answer for the engine oil.the year the car was built is 2014 and it is a 5,7 L.I´ts an automatic car which runs on gas and i think benzin.
what i need to know is how much transmission oil, front axle and rear axle and transfer case oil i have to put in.
it would be absoloutly amazing if someone could tell me
thank you:)
J
j6n69
Haren
5.7L
for all of them?
thank you for your response
Administrator
Go on the https://www.amsoil.com/ website and you can look up the various oil/lube needed for the truck and amounts.
You'll need to know what transmission and transfer case type to get the correct lube.
Transmission shift knob is the ZF 8 speed, if the truck has a column or console shifter it's the RFE 6 spd
If the transfer case has the Auto 4X4 button it's the BW44-44
You may need friction modifier if the trucks rear differential is limited slip type. It doesn't hurt to use it if the differential is not.
OC455
Central NY
This ^^^ Amsoil.com will give you the capacities for sure.
txram956
